relay isolate
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=47482
Printed Date: May 15, 2026 at 2:43 AM
Topic: relay isolate
Posted By: harrisell1
Subject: relay isolate
Date Posted: January 11, 2005 at 8:00 PM
Does anyone have the wiring info on a 2001 impala?  Reason I'm asking is because the wiring sheet I have says, for remote start I must relay isolate the park light wire from the BCM to avoid the SERVICE ENGINE SOON from coming on.  What is relay isolate?  I know what diode isolate is.  I'm going to install a Commander 7000 which has the alarm & remote start, also I was wondering which bypass to use the 555t or 555L?  Could I use the 456G for the locks & dome supervision to save some time or is that for certain GM vehicles.  Is there a similar product like 456G for GM, that Ford, Chysler,  & Mazda make? I have done quite a few of these remote starts with alarms but not on this particular car.  Thanks in advance if anyone can help on these question?
electronics
Posted By: mo12v
Date Posted: January 11, 2005 at 10:04 PM
Installation isn't to bad.  Haven't had the "Check Engine lite" problem
OMEGA makes a ByPass kit:  DB-PASS-23 or PASS-2
Constant 12 voltsREDIGNITION SWITCH HARNESS
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightD BLUE/WHITE (-)B.C.M. IN DRIVER KICK PANEL *
Trunk Pin SwitchRED / BLACK (-)AT LIGHT IN TRUNK OR BCM
Parking LampBROWN / WHITE (+)AT JUNCTION BLOCK IN PASSENGER KICK
Power LockORANGE / BLACKAT BCM ON DRIVER SIDE **
Power UnlockSINGLE WIRE SYSTEMOF INST PANEL
* DARK BLUE - Pin A1 Conn.C1 Also At B.C.M In Gray Plug On Left Hand Side. (Alternate Dome Lt. Connection). ** ORANGE / BLACK Door Lock Wire Must Receive A Ground (-) Pulse Thru A 470 Ohm Resistor To Lock And A Solid Ground (-) Pulse To Unlock.
Single Wire Resistor Door Locks
Accessories
Window UpD\ D BLUE P\ L BLUE D\ D GREEN P\ L GREEN @ MAIN SWITCH
Window DownF/ BROWN F/ TAN R/ PURPLE R/ PURPLE
Ign Key WarnL GREEN (-)STEERING COLUMN HARNESS OR BCM
Trunk ReleaseL BLUE (+) *AT BCM ON DRIVER SIDE INST PANEL
OEM HornBLACK (-)STEERING COLUMN HARNESS OR BCM
HeadlightsYELLOW (-)AT HEADLIGHT SWITCH OR BCM
OEM Alarm ArmN/A
OEM Alarm DisarmLT GREEN (-)AT BCM ON DRIVER SIDE INST PANEL
* Trunk Release Alt conn:BLACK (-) At Switch Just To The Left Of The Column.
Reversal Rest At Ground Power Window Circuit
Positive Pulse Trunk Release
Remote Start
Tach SignalWHITEAT IGNITION CONTROL MODULE *
Ignition #2D GREENIGNITION SWITCH HARNESS
Ignition #3ORANGEIGNITION SWITCH HARNESS (HVAC)
AccessoryBROWNIGNITION SWITCH HARNESS
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightWHITE (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightL GREEN (+)AT LIGHTS
Rear Window DefrostN/ATIMER BUILT INTO SWITCH
* Ignition Control Module Is Located On Top Of Engine
GM PassLock II
** Pass Lock Wires Are 22 Gage YELLOW,BLACK,WHITE Behind The Radio With The Ignition Wires Note : The Engine Will Not Turn Over Until The PassLock Is Connected
MO
