keyless enrty dodge ram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=47525
Printed Date: May 14, 2026 at 6:26 AM
Topic: keyless enrty dodge ram
Posted By: dadz
Subject: keyless enrty dodge ram
Date Posted: January 12, 2005 at 11:30 AM
Anyone got a diagram for relay wiring for 99 dodge ram keyless.
Posted By: thepencil
Date Posted: January 12, 2005 at 11:39 AM
DODGE, RAM PICKUP, 1999, Power Lock
Power Lock ORANGE / purple
Keyless models use positive trigger for lock, and 5-wire for unlock. Can also find wires at the central timer module to the right side of the steering column, lock is ORANGE / green, unlock is pink/green.
DODGE, RAM PICKUP, 1999, Power Unlock
Power Unlock pink/purple
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Posted By: dadz
Date Posted: January 12, 2005 at 12:23 PM
will the 5 wire alternating positive trigger diagram avaialable on 12volt work?
Posted By: jaurora
Date Posted: January 12, 2005 at 12:26 PM
With the 5 wire you have to cut the wire. One thing is when hooking up the keyless make sure you know what wire is switch side and what wire is motor side.
MECP certified (If it really means anything)
Jeremy
Posted By: dadz
Date Posted: January 12, 2005 at 12:46 PM
Thanx
