2002 dodge ram keyless entry
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=47579
Printed Date: May 13, 2026 at 11:45 AM
Topic: 2002 dodge ram keyless entry
Posted By: ridgewayguy
Subject: 2002 dodge ram keyless entry
Date Posted: January 12, 2005 at 9:05 PM
i need a wiring diagram to install keyless entry to a 2002 dodge ram 4 door
markus
Posted By: auex
Date Posted: January 12, 2005 at 9:36 PM
Use the search button.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: KarTuneMan
Date Posted: January 12, 2005 at 10:18 PM
https://directechs.com/directwire/wire_body.asp?action=select&yr=3556&product=Keyless%20Entry
Heres a link for ya........automatic search button at your service........posted_image
Posted By: jcap
Date Posted: January 12, 2005 at 11:14 PM
if all you want is keyless entry for  the 2002 dodge truck. you should get the system from chrysler dealer.
a kit from the oem comes with 2 key fobs and module . the module just plug into the back off the instrument
cluster. no wiring needed.
jcap
Posted By: MinusZero
Date Posted: January 12, 2005 at 11:23 PM
 RAM FULL SIZE      2002- 2003
WIRE COLORSLOCATION
12 VOLTS CONSTANTPINK/BLACK & RED / WHITEIGNITION SWITCH HARNESS
IGNITION 1BLUE (+) (16 gauge) NOTE *3IGNITION SWITCH HARNESS
IGNITION 2 RED / WHITE (+)IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 1GREEN  (+)IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2ORANGE (+) IGNITION SWITCH HARNESS *1
STARTERYELLOW or BLUE / YELLOW (+)IGNITION SWITCH HARNESS
KEY SENSELT. BLUE (-)IGNITION SWITCH HARNESS
PARKING LIGHTSPURPLE / YELLOW (-)AT SWITCH *SEE DIAGRAM*
DOME LIGHT  *SEE NOTES* 2
POWER DOOR LOCKWHITE/ GREEN    ( - )DRIVER KICK PANEL
POWER DOOR UNLOCKSINGLE WIRE SYSTEM *SEE DIAGRAM*               DRIVER KICK PANEL
TACH SENSORNOT GREEN/ ORANGE (AC)AT IGNITION COIL
DIESEL TACHGRAY/BLACKIN BLACK PLUG AT THE PCM (Power Control Module)
BRAKEWHITE/ TAN ( + )AT BRAKE SWITCH
HORNBLACK/ RED ( - )AT STEERING COLUMN
FACTORY ALARM DISARMLT. GREEN/ ORANGE (-)DRIVER KICK PANEL
FACTORY ANTI-THEFTTRANSPONDER (GRAY KEY ONLY)Requires Immobilizer bypass module
NOTES:
*1 - This wire may not be necessary for remote starting, if the Heater does not turn on, use this wire as a second Accessory wire along with the GREEN wire.
*2 -  Each Door has a separate trigger. The Driver front door trigger is Tan(-), the Drivers Rear Door is Tan/Orange (-). These wires are in the Driver's Kick Panel. The Passenger Front Door is Tan/Red (-), the Passenger Rear door is Tan / YELLOW(-). These wires are found in the Passenger's Kick Panel. For alarms these wires must be Diode Isolated and all connected to the Negative door trigger wire. For remote starters/ and alarms when you want to activate the dome light you can use any of these wires through a negative( See bulldog unit  manual to see if this option is available on your model and if a Relay is required for activation).
*3 you will find a HEAVY GAUGE BLUE (+) wire in the IGNITION SWITCH harness, DO NOT USE THIS HEAVY GAUGE BLUE wire as IGNITION #1 use only the BLUE 16 Gauge wire as IGNITION #1.
Date Posted: January 13, 2005 at 8:02 PM
thanks for the help guys
markus
