2002 Saturn SCI Wiring for a Manual trans
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=47614
Printed Date: May 13, 2026 at 2:25 PM
Topic: 2002 Saturn SCI Wiring for a Manual trans
Posted By: stevedore
Subject: 2002 Saturn SCI Wiring for a Manual trans
Date Posted: January 13, 2005 at 11:30 AM
Does anyone have the wiring diagram for  my 2002 Saturn SC1 which is a standard. I am looking to install my remote starter and have not been able to source the wiring specs/diagram
I look forward to receiving anyones assistance.
Steve
Posted By: extreme1
Date Posted: January 13, 2005 at 11:59 AM
12V red
ign pink
acc orange
start -purple at the clutch switch
park/brake- lt.blue, center console
door- grey/black drivers door by diag plg, pass door GREEN/ black center console back of fuse box
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Date Posted: January 16, 2005 at 4:07 PM
Do you know where the Door Trigger wire is as well as the color. Also is this wire + or -.
Steve
Posted By: johnnydi77
Date Posted: January 18, 2005 at 6:25 PM
Use white neg for door trigger. You don't have to use independent door triggers because there is no delay with the ignition on.
John J. DiStefano Jr.
Date Posted: January 18, 2005 at 6:26 PM
Sorry forgot to teel you the location. It's located behind the fuse block.
