Astrostart 2505 to OM-passlock-5
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=47669
Printed Date: April 18, 2026 at 1:54 PM
Topic: Astrostart 2505 to OM-passlock-5
Posted By: magnarider
Subject: Astrostart 2505 to OM-passlock-5
Date Posted: January 13, 2005 at 10:23 PM
Can the new Astrostart OM-PASSLOCK-5 (part no.310-907-551) interface to the Astrostart 2505 (BDA main unit) through a 310-909-000-00 harness (P16) as follows?:
-green (ground when running input) -------go to --------P16-green: output (-) when running
-pink ( ignition input (connect to P4-4))---go to---------P16-orange: output anti-theft (-) or as Note #1
-red (12 volt input (connect to P4-7))-----go to---------P16-red: +12VDC
-black (ground input)----------------------go to---------P16-black: ground
Note #1 Or must I use Programmable output 1 or 2 on wire P16 BROWN / white or WHITE/ blue, programmed as "ignition"
Cool 8D rider
Posted By: KarTuneMan
Date Posted: January 14, 2005 at 12:33 AM
You need to tell what kind of vehicle your working on, AND what type of passlock you need to achive. This unit does a bunch of em..........Sounds like your looking at the rite stuff.   Move foward young Man
Date Posted: January 14, 2005 at 6:37 PM
Hi KarTuneMan
The vehicle is a 93 Pontaic Bonnie with a vats or pass-key II anti-theft system. Today,I found out from my Astroflex dealer in Edmonton, ALberta, Canada that the OM-PASSLOCK-5 is manufactured by a contractor and not Astroflex, therefore the 310-909-000-00 harness (P16)is not included in the OM-PASSLOCK-5 (part #310-907-551). I just need to know if the P16-orange: output anti-theft (-) is the same as the Programmable output 1 or 2 on wire P16 BROWN / white or WHITE/ blue, programmed as "ignition".
TKS for you HELP
Cool posted_image rider
