2001 toyota echo
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=47672
Printed Date: April 19, 2026 at 1:41 AM
Topic: 2001 toyota echo
Posted By: vtech010
Subject: 2001 toyota echo
Date Posted: January 13, 2005 at 10:58 PM
hello i am installing a remote starter on my echo.  i woudl like to know where do i connect  the ACC feed from the  module into the car?  is it to ignition 2? so that my bower will work.?
thank you
What do i do now?
Posted By: profuse007
Date Posted: January 14, 2005 at 2:45 AM
| SECOND IGNITION|BLACK/ red *1        |+ |ignition harness            |
*1 When doing remote start, this wire must be isolated from the keyswitch with the second ignition relay. See direct fax document #1077
Houston,TX
Posted By: vtech010
Date Posted: January 15, 2005 at 9:24 PM
what is the reason for this, for adding the realy?  what iof i just out it direct from the remote start module to the sende ignition what will happen  then?
What do i do now?
Posted By: KarTuneMan
Date Posted: January 16, 2005 at 1:42 AM
The starter will......GRIND!!!!
