Camry 98 Door trigger (-)
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=47719
Printed Date: April 18, 2026 at 3:34 AM
Topic: Camry 98 Door trigger (-)
Posted By: vl3tfun
Subject: Camry 98 Door trigger (-)
Date Posted: January 14, 2005 at 5:33 PM
I got & check the door trigger wire ! It is +12v when door closes, and it is about +0.15v when a door opens.  The alarm works well except the door trigger, the alarm doesn't know if a door opens. Is there another wire for door trigger ? Please help me ! Thanks.
Posted By: corraudio
Date Posted: January 14, 2005 at 6:12 PM
Which wire did you use?
Posted By: vl3tfun
Date Posted: January 14, 2005 at 6:45 PM
I used the RED / White wire at the driver's kick panel.
Posted By: KarTuneMan
Date Posted: January 14, 2005 at 8:27 PM
Did you check the door trigger from the drivers door, or another door?
The drivers door on some models with factory security, has a seperate door pin....   GRN/RED NEG(-)
Posted By: mo12v
Date Posted: January 14, 2005 at 8:57 PM
It will show 12 volts when doors are closed.  Make sure you are on the right wire
RED / WHITE (-)7 PIN CONNECTOR AT THE FUSE BLOCK
MO
