Conpustar Paging Problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=47803
Printed Date: April 18, 2026 at 6:35 AM
Topic: Conpustar Paging Problem
Posted By: mk5FSI
Subject: Conpustar Paging Problem
Date Posted: January 15, 2005 at 7:08 PM
I have a Nustart model NUA 3000 paging alarm system.  Its the same alarm as the compustar cm3300.  This alarm has the am paging function but it only seems to work when i have the remote about 3 inches away from the antenna.  What could be causing this very short range in the paging function.   Any help would be greatly appreciated.
Derek
Posted By: mk5FSI
Date Posted: January 16, 2005 at 10:27 PM
Oh yeah forgot to mention that the keyless entry works fine from very far away but the paging does not.   Thanks
Posted By: Velocity Motors
Date Posted: January 17, 2005 at 9:44 AM
It's the antenna, go back to the place that you got the system and ask for a replacement antenna. This will fix the range problem that you have.
Posted By: jdmmaSTER
Date Posted: January 18, 2005 at 10:45 PM
let us know if the above works because I am also having a paging problem with my 790xv
Assumptions are the ideas of fools
