nissan 300zx Clifford problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=47805
Printed Date: April 18, 2026 at 5:49 AM
Topic: nissan 300zx Clifford problem
Posted By: gixxermoto
Subject: nissan 300zx Clifford problem
Date Posted: January 15, 2005 at 8:11 PM
I have a Solaris Clifford alarm installed in my nissan 300zx.  The  problem i'm having is when the car is siting, it will go into antiheft, i beleive.  The alarm will make this loud tap noise about every 3 seconds.  You are not able to start the car at this point.   I discovered that if i wiggle the electrical harness it seems to reset.  Now nothing seems to be working.  Is the brains fried??  How can i bypass the alarm so that i can get my car started??
Posted By: Teamrf
Date Posted: January 15, 2005 at 8:22 PM
You can always un-plug the brain.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Posted By: italnpimp59
Date Posted: January 15, 2005 at 8:27 PM
first off check to see if you have any blown fuses.  second question i have is how did you connect your wires?  it sounds like you may have not connected them the way they are supposed to be...soldered and taped...and connections are coming loose so when you wiggle it, the alarm works again
Date Posted: January 16, 2005 at 11:06 AM
When the brain is unpluged and I try to start my car, you can turn the key but nothing happens at all.  I have checked that electrical clip that connects to the brain and there is no loose wires at all.  I guess what i really need to know is how to disable the alarm?
Date Posted: January 16, 2005 at 7:31 PM
did you put a starter kill on this alarm?
Date Posted: January 17, 2005 at 12:55 PM
yes, the alarm has the starter kill feature.
