eclipse anti start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=48031
Printed Date: May 02, 2026 at 12:18 PM
Topic: eclipse anti start
Posted By: mitsushocker
Subject: eclipse anti start
Date Posted: January 18, 2005 at 6:28 PM
Mistushocker would like help with automate antitheft/ keyless entry that seems to be inhibiting start of a newly bought 1997 Mitsubishi Eclipse GS M/T. I have taken apart a few engines in my time, 2 of this same make/model, am a pilot of 7 years, college grad with honors etc... etc.... etc.... so I have a little know how of wiring, schematics, and how stuff works. Some things just dont seem to make sense and I hope someone might help. I have just taken apart the engine of my 97 Eclipse GS to install head gasket, water pump, and timing belt beacaue there was a slight oil/pressure leak from #4 cylinder. May as well get timing belt and water pump while all is apart of course... :) After putting all the parts back together, I put the key into the ignition, turn 2 clicks, and tighten down the neg side of batt. to override Automate 467 setting off alarm etc, try to start, nothing. Push the door open and close button on the remote and try again, still nothing. All except a check engine light that flashes until I shut the alarm off and a clicking near my left foot. Tried to reset alarm and ECS many times, still stumped, checked fuses, and even tried to pull the onboard anti-theft fuse. (manufacturer as well as aftermarket anti-theft) Have tried many combinations of disconnecting battery and pushing remote buttons even for extended time periods. My solution is that a elec switch is stuck somewhere in the alarm and to cut out the automate. Any other suggestions would be appreciated....
leave a msg after the beep beep.....
Date Posted: January 18, 2005 at 7:05 PM
ok well I have one adjustment to my claim.... the remote is automate 467, unsure exact model automate ... will investigate and post update....posted_image
Posted By: auex
Date Posted: January 18, 2005 at 8:56 PM
auex would like a million dollars. auex would like people to quit referring to themselves in the third person. auex would like a ferrari. auex would like a multimillion dollar home in N. Scottsdale. auex would like to own his own shop. auex would like to give up talking about himself in the third person.
Go under the driver's dash and look for the starter wire or alarm. Follow the wiring to the starter kill relay. Cut the large gauge wires going into the relay and connect the ends. If you can locate the starter wire with out finding the alarm then find where it is cut and spliced into the relay and reconnect.
auex has spoken.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: January 19, 2005 at 4:45 PM
working with an automate model #2, remote 467, possibly looking for a wiring diagram for disconnect/ reconnect ignition/ starter wiring ........
Date Posted: January 19, 2005 at 8:13 PM
disconnected automate, reset ecu, car started....
thanks for the help posted_image
 posted_image
