parking light stopped working ?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=48112
Printed Date: May 02, 2026 at 8:38 PM
Topic: parking light stopped working ?
Posted By: kslmgd
Subject: parking light stopped working ?
Date Posted: January 19, 2005 at 1:54 PM
I installed boa 256b in bonnie 92 model
I used the - to + relay trick it had neg trigger for parking light (white wire)
light switch wire(brown) was postive
everything worked fine for one day ?
checked wire with light all connection good
could relay be bad }:)
12v 30 amp relay
kslmgd
Posted By: misterjimbo
Date Posted: January 19, 2005 at 2:26 PM
did you check to  see if there is outpur from alarm? if so is there output from relay? does the relay still have power going into it?
