2004 rav4 door trigger
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=48308
Printed Date: April 02, 2026 at 4:35 AM
Topic: 2004 rav4 door trigger
Posted By: latuszek
Subject: 2004 rav4 door trigger
Date Posted: January 22, 2005 at 7:15 AM
Hey everyone, this is such a great forum! I am having a problem with the door trigger in a 2004 rav4.   The two sources I have found on these forums said either red or RED / yellow in the wire harness going under the driver's seat. First off there is like 0 slack on these wires which makes it hard to find the wire and impossible to splice.
Is there really no other (easier) way to get a door trigger? Thanks for any help!
Posted By: KarTuneMan
Date Posted: January 22, 2005 at 8:25 AM
What you have listed IS the way to do it.....posted_image
Posted By: JWorm
Date Posted: January 22, 2005 at 5:51 PM
TOYOTA, RAV4, 2004, Door Trigger
The individual door trigger wires are at the passenger side junction box behind the glove box. The driver door trigger is RED / yellow in a 10 pin plug in pin 3, the front passenger door is RED / white in a 20 pin plug in pin 5, and the rear doors and hatch is RED / white in a 10 pin plug in pin 2.
Posted By: muppet
Date Posted: January 23, 2005 at 2:40 AM
have you got a door open light on the dash if so could use the feed on the back of the dash.
paul
