SILVERADO 2002 WIRING DIAGRAM
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=48343
Printed Date: May 16, 2026 at 10:16 AM
Topic: SILVERADO 2002 WIRING DIAGRAM
Posted By: aureli
Subject: SILVERADO 2002 WIRING DIAGRAM
Date Posted: January 22, 2005 at 8:36 PM
HI. I can not find the factory disarm alarm cable, I now that is light green and is located in the kick panel. Also I dont now where is the tach cable, if somebody can help me I woul apresiate it thanks..
Edward
Posted By: mo12v
Date Posted: January 22, 2005 at 9:06 PM
U might try a odd color Fuel Injector wire for TACH also
OEM Alarm DisarmL GREEN (-)AT B.C.M. BELOW THE STEERING COLUMN*
* There Are 3 Connectors In The BCM. The Disarm Wire Is Located In The Violet Connector
Tach SignalWHITEFOR THE V-8 AT THE P.C.M. *
* Power Control Module Located At The Left Front Of The Engine Compartment Pin 10 of the 80 pin connector. WHITE-For The V-6 At The Coil On Top Of The Engine
MO
Posted By: aureli
Date Posted: January 23, 2005 at 12:40 PM
Thank you I gat the factory disarm cable.I just have to fine the tach cable.
Edward
Posted By: iskidoo
Date Posted: January 23, 2005 at 2:08 PM
Make certain you hook up all listed Ignition wires during remote start or you will damage your transmission. The vehicle will start without powering up all of them but when you drive off after remote starting the transmission will not shift correctly.
