wierd tach signal hookup
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=48358
Printed Date: May 16, 2026 at 4:22 AM
Topic: wierd tach signal hookup
Posted By: nautica2o3
Subject: wierd tach signal hookup
Date Posted: January 23, 2005 at 2:32 AM
I am trying to install a remote starter into a 1998 Mercury Villager. The manual says to wrap the tach signal input wire around the high ignition coil wire 5-7 times. I have installed remote starters in my other cars before, and the tach signal wire was always soldered directly to a bare wire in the ECU or tachometer, not just wrapped around the ignition coil wire. Has anyone installed a remote start with this kind of tach signal input before? Do I just wrap it around the wire coming from the ignition coil to the distributor? What wire should I use to coild this input wire around?
Posted By: cutter1122
Date Posted: January 23, 2005 at 2:38 AM
spakplug wire
Posted By: auex
Date Posted: January 23, 2005 at 2:53 AM
What alarm is it, probably phoenix digital? Next alarm make sure you are getting a better one.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: January 23, 2005 at 3:07 AM
Yeah, it was a cheap one that I got for my beater. I think the box had Cyclone in red lettering on it. The manual has a silver Jaguar on the front. It was an impulse Ebay purchase. I will definitely get a better one next time from a real company.
I will try the sparkplug wire and hope it works.
Thanks.
