remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=48452
Printed Date: May 15, 2026 at 4:15 AM
Topic: remote start
Posted By: bigbluehemi
Subject: remote start
Date Posted: January 24, 2005 at 6:47 AM
i have a audiovox asp 786 and i ve hooke up all the leads but it will not learn the tac signal. the wire diagam is vage to say the least i have a 2003 dodge ram 1500 with the 5.7 v8. it has a coil pack on each cilender so im not sure were to hook up the lead for the tac. thanks for your help im lost
Posted By: soundmasta
Date Posted: January 24, 2005 at 7:18 AM
first of all, did you hook up all of your acc and ign wires? some units won't program without seeing power at the 2nd ign wire. i expect you did, but my rule is to always check the obivous first. sow, im not very fimiliar with the audiovox ( i've only ever installed 3 of them) but if it's not a total box of sh*t like an astroflex or somthing it shouldn't be too picky about where you pull tach from. the tan/red at the first ign coil sould work. i have another source that says NOT GREEN/ orange at ign coil, coil pack or an injector, which is a general rule of thumb-pull signal off of the uncommon wire.
