My 791xv goes off when I open the door
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=48465
Printed Date: May 14, 2026 at 10:00 PM
Topic: My 791xv goes off when I open the door
Posted By: foxhound
Subject: My 791xv goes off when I open the door
Date Posted: January 24, 2005 at 10:49 AM
Several times I have my remote die while I'm not in the truck and the alarm is armed and so I have to use the key to unlock the door to get inside. The thing is the alarm goes off and I usually end up digging in my center console looking for a AAA battery to replace the one in the remote with. Is this normal or is there a wire missing that should disarm the alarm when I unlock with a key?
Posted By: foxhound
Date Posted: January 24, 2005 at 10:50 AM
Oh ya its a 03 Chev S-10 with a Viper 791xv.
Posted By: Ravendarat
Date Posted: January 24, 2005 at 11:17 AM
No thats the way it suposed to work. It only disarms with the remote.
Posted By: daniel2002p
Date Posted: January 24, 2005 at 1:06 PM
only factory systems disarm with the remote, while aftermarket like the 791 go off to protect your vehicel in case somebody jacked your key.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Posted By: jimmeezgolfvr6
Date Posted: January 24, 2005 at 2:23 PM
there's no valet switch? i can't remember the 791xv very well, but i recall that pretty much every dei product has a valet switch.
all problems can be resolved with a hammer
Posted By: Jschult3
Date Posted: January 24, 2005 at 4:38 PM
Yeah it has a valet switch, as long as it was installed. If not you can hook it up for about 2.00 or go back to the shop and ask them to do it for you. Basically you have a preset # of pules the valet switch has to be hit to disengage or turn off the alarm. If you had it installed they probably use a default setting of "x" times and can show you how to do it.
PS- if your remote keeps malfunctioning you may need a new one. those remotes are a little fragile if you throw them around.
Always Verify Wire information before Connecting! Just a Darn Good DIY'R
Posted By: kgerry
Date Posted: January 24, 2005 at 5:01 PM
make sure to mention the valet switch only works in conjunction with the ignition key.... you put the key in and turn it to ign, then press the valet switch to shut off the alarm.... if you dont have a spare battery you're buggered cause the starter kill wont allow you to start the vehicle with shutting it down first.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
