1999 Chevy Astro, remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=48499
Printed Date: May 14, 2026 at 10:30 AM
Topic: 1999 Chevy Astro, remote start
Posted By: 2faded
Subject: 1999 Chevy Astro, remote start
Date Posted: January 24, 2005 at 4:32 PM
I am a newbie installer...I have successfully done a Design Tech remote start/keyless on a 1992 accord no problem.  I moved on to a 1999 Astro van which has Passlock II, no chip in the key.  I put in an Auto-Page 655 alarm, remote start and keyless.  Everything works fine, passlock seems to be good, but occassionally when i use the remote to start the car, it will shut off in about 30 seconds and then SOMETIMES retries  to start it self.
Summary..............
car starts fine with key, shuts off occassionally after 30 seconds when started with remote..
Any help is greatly appreciated..Thanks
Posted By: kgerry
Date Posted: January 24, 2005 at 5:13 PM
relearn your tach signal..... sounds like it's cutting out when it kicks down....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: MAS952
Date Posted: January 24, 2005 at 8:06 PM
ok, so relearn the tach?
Stupid question, but how do i do that?? I probably know how to do it but never was taught about "learning" the tach
thanks
Midwest Auto Salon
7604 147th Street
Apple Valley, MN 55124
952-997-7113
Posted By: kgerry
Date Posted: January 25, 2005 at 1:45 PM
well i presume you had to learn tach when you installed the unit..... if you didnt that may be the problem right there......
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
Posted By: MAS952
Date Posted: January 28, 2005 at 11:59 AM
ok i checked the tach at the source, it shows life. i probed it from the back of the unit to see if signal was sent thru to the unit and it shows life.  starts fine with the key.  i switched out the brain for another rs-650 and reprogrammed it and the unit wouldnt even get a signal to start the car.  so now im thinking it HAS to be the autopage units.  waiting for their tech support and no answer yet!!
moral of story----Autopage sux???
Midwest Auto Salon
7604 147th Street
952-997-7113
Posted By: Velocity Motors
Date Posted: January 28, 2005 at 1:02 PM
You have to learn the unit to the vehicle's tach. Without doing this, the unit will not know that the car started and will auto shut down to prevent possible damage to the vehicle.
