2002 saturn sl1/sl2 wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=48546
Printed Date: May 13, 2026 at 7:38 PM
Topic: 2002 saturn sl1/sl2 wiring
Posted By: misterjimbo
Subject: 2002 saturn sl1/sl2 wiring
Date Posted: January 25, 2005 at 8:04 AM
is the wiring in a 2002 sl1 the same as an sl2? i did one this weekend and a few days later it popped a check engine light on. i reviewed the wiring for an sl2 (it was an sl1) and it appears that i did everything correctly. i do not remember if i used a relay to power the keysense wire or not, i might have jsut used the ground when running... hmmm maybe i stumbled onto the solution already. if that isnt it do you have any other ideas.
Posted By: thepencil
Date Posted: January 25, 2005 at 9:43 AM
SATURN, S-SERIES, 2002, Keysense
The lt. green key sense wire at the steering column must see a ground during remote start to keep the SERVICE light from coming on.
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Posted By: meltingplastic
Date Posted: January 25, 2005 at 9:53 AM
you have to use a relay from what i know
Driving a Bagged, Caddied 02 s10
Date Posted: January 25, 2005 at 10:03 AM
Just remmbered. I did a audiovox 996a. Used the dedicated port for my bypass trigger and power which left the neg 300ma 3rd ignition available. I fugured that it would be no problem to power up the keysense with it. I do know that when I shipped the car the chime was going off when remote starting with door open. Maybe the output blew? That is why the service engine lt came on? Any other help? I love this place
