02 expedition GEM wake up
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=48567
Printed Date: May 13, 2026 at 3:59 PM
Topic: 02 expedition GEM wake up
Posted By: Hymer
Subject: 02 expedition GEM wake up
Date Posted: January 25, 2005 at 1:33 PM
Anyone know where this wire is .. yell/black or black yell??? I think its in the dr kick, but I'v treid about every wire there with a - pulse and she won't wake up... anything??
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
Posted By: KarTuneMan
Date Posted: January 25, 2005 at 1:47 PM
Its BLACK / YELLOW......its the drivers door pin @ the pcm.  You need to isolate this wire from the pcm.
Or "break" it with a relay.....Its set up like isolating a Dodge neg parking light wire. Look in the astrochart
You can also find the wire in the drivers door boot!
You can use your pulse before and after trigger wires on the same relay. One to wake up.....and one to shut off the radio after run time
Posted By: Hymer
Date Posted: January 25, 2005 at 2:39 PM
Thanks guy.. I appreciate it!!! it worked great...
Later
Date Posted: January 25, 2005 at 6:28 PM
KooL......
