Toyota Previa 94 stock alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=48617
Printed Date: May 13, 2026 at 2:37 AM
Topic: Toyota Previa 94 stock alarm
Posted By: mickeyvnminnie
Subject: Toyota Previa 94 stock alarm
Date Posted: January 25, 2005 at 11:29 PM
Hi,
 I couldn't the wire to disarm the stock alarm. Can anyone pls help? Please be as much detail as possible. Thank you for your time.
Mickey
Posted By: KarTuneMan
Date Posted: January 27, 2005 at 9:00 AM
That vehicle should arm with lock, and disarm with unlock.
So get the lock wires and you should be fine!
Posted By: mo12v
Date Posted: January 27, 2005 at 9:07 AM
Try this:
OEM Alarm ArmBLUE(-) GRAY 8 PIN CONNECTOR/DRIVER KICK
OEM Alarm DisarmBLUE/WHITE(-) GRAY 8 PIN CONNECTOR/DRIVER KICK
MO
Date Posted: January 28, 2005 at 2:17 PM
mo12v] wrote:
p>Try this:
I'll try it tonight and let you know the result. Thanks much
