Program switch not responding on 791xv
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=48622
Printed Date: May 13, 2026 at 6:19 AM
Topic: Program switch not responding on 791xv
Posted By: jmw57
Subject: Program switch not responding on 791xv
Date Posted: January 26, 2005 at 1:35 AM
Not sure what happened, it was working before. I had just attached the tach wire and was going to program it to learn the tach signal. But it doesnt respond to anything. Everything else works fine though. Although i have yet to try the remote start.  Alarm, door locks, shock sensor, door trigger, you name it everything else is working like it should. Somebody please tell me how to fix it.
Posted By: jaurora
Date Posted: January 26, 2005 at 7:47 AM
The only thing I can think of is that 1) it is not pushed in all the way or it is plugged into the wrong spot. It uses the same connector as the LED. Just double check. I know that it is color coded but it can easily be crossed.
MECP certified (If it really means anything)
Jeremy
Posted By: kgerry
Date Posted: January 26, 2005 at 9:42 AM
plus make sure you have the right tach source, because it wont light the LED if you dont......
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: jmw57
Date Posted: January 26, 2005 at 3:05 PM
well i cant access any menus with it or anything. I actually dont care as long as everything is up and running fine, but dont you have to learn the tach signal before you can remote start the vehicle?  I have double checked all the wires, the green needed to see the doors, the pink for ignition, and everything that is neede to use the program feature. The Led works fine , i think ill head to radio shack and grab another switch button just for the hell of it. If that doesnt work .....   I have no idea what i will do
Posted By: vinman75
Date Posted: January 28, 2005 at 12:06 AM
make sure your flat ribbon remote start cable is plugged all the way in at both ends. The alarm gets its ignition feed through there.
Posted By: Javelin3o4
Date Posted: January 28, 2005 at 12:58 AM
similar issue with my today, was trying to program a 350hv for double pulse and it wouldnt program, turns out my yellow ignition wire wasnt in all the way. After that i said screw it with the valet and got a bitwritter.
Posted By: dare_ds69
Date Posted: January 28, 2005 at 7:13 AM
some times the tach goes bad you can program tachless. of course if the brain let you go into the progran mode. try to use a bitwritter.
how own your mind, control your life.
MECP certified. always use a DMM
Posted By: jmw57
Date Posted: January 28, 2005 at 3:19 PM
Ya i think its dead, im just gonna have to buy a bitwriter, i still need to buy and program a companion remote for my wife. Every function on the alarm , including the remot star works just fine though.
Thanks for your input
Posted By: jmw57
Ya i think its dead, im just gonna have to buy a bitwriter, i still need to buy and program a companion remote for my wife. Every function on the alarm , including the remote start works just fine though.
Posted By: zzimerclan
Date Posted: January 29, 2005 at 12:07 PM
jmw57!     I finally got mine to work! I just kept trying! I did not change anything just tried and tried??     go figure!  SZ
Posted By: jmw57
Date Posted: February 10, 2005 at 2:05 AM
well i will have to try that, its very strangethat it would just start working agin like that, but hey whatever works right!!!
Posted By: gus1
Date Posted: February 10, 2005 at 1:46 PM
Make sure the main brain is recieving a positive ignition signal on the yellow wire of the ribbon cable. I have had a couple that had poor solder joints on the XCRS side of things.
Gus
