BMW parking light problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=48704
Printed Date: May 02, 2026 at 9:15 AM
Topic: BMW parking light problem
Posted By: dare_ds69
Subject: BMW parking light problem
Date Posted: January 27, 2005 at 7:13 AM
I did an alarm & remote starter on BMW 325 everything works, but when the car starts the head light turn on and when i unlock the doors the head light flashs as the parking lights. the problem is the hid is going to damage. the other problem is when the remote start turn off the dome light turn on and it triggers the alarm.
Does some one know what can I do to fix the problems? I will apreciate any info thanks.:D
how own your mind, control your life.
MECP certified. always use a DMM
Posted By: mo12v
Date Posted: January 27, 2005 at 8:51 AM
What Year BMW?
MO
Posted By: metaverse
Date Posted: January 27, 2005 at 11:03 AM
Please read how to post in this forum. Post the alarm make/model and the car year/make/model. It saves time from asking the basic questions so folks can attempt to help..
A lot of aftermarket alarms have the light flashing option when remote started as a feature. Post more about the alarm make and car's year..
Date Posted: January 27, 2005 at 5:58 PM
sorry is a bmw 325ci 2000 and I used a 550esp viper.
Posted By: xtreme069
Date Posted: January 28, 2005 at 12:08 PM
can't help with the problem only to say that i have done a few of these cars and had no problem as long as you interupt the parking light wire in the ribbon used in the light switch box check that and also that you don't have the auto lights turned on
Know i have a question what bypass module did you use as i'am yet to find one that works with the e46
I Love This Industry!!
Date Posted: January 28, 2005 at 12:12 PM
can't help with your problem only to say that i hace done a few e46 models and haven't had any problems with the lights just make sure you have interupted the correct wire in the light switch box
i have a question for you what bypass module did you use for this car as i'am yet to find one in australia that works any help would be much appreciated
Posted By: mxxmikexx
Date Posted: January 28, 2005 at 4:18 PM
im not sure if this link will work for you without a password, but here is the tech info for the light circuit
https://www.directechs.com/techtips/pdfs/resources/security/directed_techtips/1055.pdf
Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
Date Posted: January 29, 2005 at 7:32 AM
i try everything the problem is only when the car is in remote start the head light flash when the car is off and you press the unlock just the parking lights flash thas really stupid right. i will use another realey thanks any way.
the module that i used was 555b wish didn't work. so I used 555me just get the factory ring use the power locks plug the alarm. to conect behind the factory ring, then i use a relay. you have to cut the factory wire and conect to the relay is easy.
Date Posted: February 01, 2005 at 2:40 AM
sorry but i can't understand how you have wired up the bypass maybe draw me a diagram and also can't find a 555me anywhere cheers!!!
