2001 siverado remote starter help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=48708
Printed Date: May 02, 2026 at 6:39 AM
Topic: 2001 siverado remote starter help
Posted By: makerxw
Subject: 2001 siverado remote starter help
Date Posted: January 27, 2005 at 7:40 AM
Im installing a commando 5005 starter alarm combo not sure what i need to do. im having problems with the starter portion. i keep getting the security light and the starter will not start . it just cranks. Any help would be great. btw my truck is basic no electric locks or doors all i want is the alarm to work and for it to start!!
jim cooper
Posted By: kgerry
Date Posted: January 27, 2005 at 8:16 AM
What module did you use to bypass the Passlock II feature ??
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: Velocity Motors
Date Posted: January 27, 2005 at 8:30 AM
You need to bypass the Passlock II system otherwise the truck will never start. You will need a GMBP or PLXR for this truck to be remote started.
Posted By: makerxw
Date Posted: January 27, 2005 at 4:24 PM
thanks for the replys i finally got the starter to work. i had to buy a 555 bypass that learns the system and im gonna return the cheap bypass that you had to flip dip switches to get it to work   thanks again
jim cooper
Posted By: kgerry
Date Posted: January 27, 2005 at 4:27 PM
like i always say.. a job goes a lot easier when you start with quality gear.....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
