Avital 2200, 451M DEI Lock solenoid?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=48945
Printed Date: April 24, 2026 at 6:11 PM
Topic: Avital 2200, 451M DEI Lock solenoid?
Posted By: dynotuned
Subject: Avital 2200, 451M DEI Lock solenoid?
Date Posted: January 30, 2005 at 3:44 PM
I have an old avital 2200 that I am currently trying to wire into a car of mine right now that I got out of a parts car and it doesn't have any instructions to go along with it.  I am doing good enough without it but I have a few questions.  One, is the Starter Kill relay built into this model, and if so, are the two black wires the part of the starter kill coming out of the box.   Second, I was wondering if any of you knew how to wire in the 451M door lock relay to this box and the two aftermarket lock solenoids that i have? Thankyou
Posted By: kiteman
Date Posted: January 30, 2005 at 5:27 PM
  If you have 2 black wires coming out of the box by them self, that is the starter kill wires does not matter which side goes to which.  on the 451. the purple wires are the 12v, then you should have a grn, grn/blk, blu, blu/blk.  the grn and the blue go to the aftermarket locks and the grn/blk and the blu/blk go to ground.
Date Posted: January 31, 2005 at 10:18 AM
Thankyou for your help, That is all i needed.
Date Posted: January 31, 2005 at 10:38 AM
actually the wires out of the 451m are WHITE/ black BROWN / black blue/black BROWN / black and two PURPLE / black that link at a fuse that i don't know where they go.  I have the the 3 small wires plugged into the box.  I have after market 2-wire actuaters and was wondering how these wires go to the actuators.  This is what it says on the back of the relay:
PURPLE / black - lock/unlock normally open#87
GREEN/ black- lock output#30
WHITE/ black- lock normally closed #87a
blue/black- unlock output #30
BROWN / black- unlock normally closed #87a
