Temp sensor, 1.5 to 3.0 hrs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=49223
Printed Date: April 26, 2026 at 11:53 PM
Topic: Temp sensor, 1.5 to 3.0 hrs
Posted By: Anthnynixon
Subject: Temp sensor, 1.5 to 3.0 hrs
Date Posted: February 02, 2005 at 4:35 PM
I just installed my temp sensor in my compustar alarm/remote starter. I programed the unit to turn on the sensor.(I & II) then (IV) 7 times, wait 7 chrips, then press (II)got 2 chrips. I have a few questions.
All that i have to do is hit (II & IV) to turn on timer mode and it will pick up the signal from the temp sensor, and use that instead of starting every 1.5 hrs, correct? I know there is an icon on my remote for the cold start, will that only light up if the remote start is activated because the temp has dropped below the setting? It also say some stuff in the manuals about it can accept a signal every 1.5 or 3.0 but it says no where how to change that feature. I would like to set that to 3hrs because the default is 1.5. Anyone know how to do that? The unit I have is the CM3000
Date Posted: February 03, 2005 at 1:36 PM
no one knows anything about this sensor or how to set the check time either 1.5 hrs or every 3 hrs?
Posted By: vektron
Date Posted: March 16, 2005 at 4:32 PM
I have the same alarm and I want to install the temp sensor, I just can't find it anywhere, not even on ebay. Can you tell me where to get one? Thanks.
Posted By: accord78
Date Posted: March 16, 2005 at 6:57 PM
just get a dei 556t valet digital time/temp remote start controller simple and easy to set that's all u need u can use it on any alarm system with a negative remote start activation or if it needs a double pulse get the dei 452t with it it's a double pulse generator
Posted By: Velocity Motors
Date Posted: March 16, 2005 at 8:51 PM
The CM3000 requires the system to be programmed to operate with the cold start sensor and you set the programming to 1.5 or 3 hours between cold starts. It's in the manual in the installation guide.
------------- Jeff
Posted By: vektron
Date Posted: March 16, 2005 at 9:50 PM
Would the dei modules allow me to see the car's temp on the 2-way remote. I think this is also a feature for this alarm, when you query the alarm from the 2-way remote it displays what the temp is outside. I think this is also a neat feature.
