98 nissan altima GLE alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=49272
Printed Date: April 27, 2026 at 10:20 PM
Topic: 98 nissan altima GLE alarm
Posted By: azn02civic
Subject: 98 nissan altima GLE alarm
Date Posted: February 03, 2005 at 12:40 PM
hey i have a question reqarding this car alarm system. (98 nissan altima GLE) the remote is lost and i need to know how to reprogrammed the new one. I looked at ebay and found some but dont no if it is the right one. and i found the wiring diagram but is there another one if the car have a keyless entry and alarm. any help would be helpful. Thanks!!!
Posted By: jaurora
Date Posted: February 03, 2005 at 2:58 PM
That is for the dealership if it is a factory system!
MECP certified (If it really means anything)
Jeremy
Date Posted: February 04, 2005 at 11:44 AM
Any one know how to program the new remote control for this car Please help!!!
Posted By: jaurora
Date Posted: February 04, 2005 at 11:57 AM
Like I said,
If it is an aftermarket we can help, if it is factory you need to go to the dealer or check your car manual.
Jeremy
Posted By: metaverse
Date Posted: February 04, 2005 at 11:39 PM
Here are the instructions for 1995-1998 Max:
Enter the vehicle, close and lock all doors. Insert and remove key from
ignition 6 times within 10 seconds. Tail Lamps will flash to indicate
original code has been erased. Turn ignition to the ACC position. Press
LOCK button on 1st transmitter. Tail Lamps will flash to confirm
programming. To enter additional transmitters, unlock then lock the doors
using the power switch located on the driver door. Press LOCK button on
the additional transmitter (up to 4 transmiters total possible). tail
lamps will flash to confirm programming. Open drivers door, turn ignition
to OFF.
