trunk pops open
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=49476
Printed Date: April 30, 2026 at 6:30 PM
Topic: trunk pops open
Posted By: toymrj
Subject: trunk pops open
Date Posted: February 06, 2005 at 11:21 AM
anyone have a problem with the trunk poping open when u press the lock button on the remote or it does it when i put the key in the ignition to the on position it will pop open? i tried to use the two different wires on the alarm that r for the trunk pop but theyt both do the same thing. so im out of ideas. i have the crimestopper rs2011IV series on a 99 mazda 626. maybe does it need a relay on it?
Posted By: toymrj
Date Posted: February 06, 2005 at 11:49 AM
well on my alarm there is a GREEN/ red wire for m.a.p or for trunk pop and the other one is a blue/black ign. out or remote aux #2. than it says that connect to the neg. activation circuit of the aux device so that means if i use the blue/black wire than i connect it to the neg. of the trunk pop. if i use the GREEN/ red wire it says that optional requires relay but does not say how to hook it up to the power trunk.
Posted By: toymrj
Date Posted: February 06, 2005 at 11:56 AM
nevermind i just connected the GREEN/ red wire back together and it is fine, maybe the connector wsa a little loose.
thanks
Posted By: KarTuneMan
Date Posted: February 06, 2005 at 12:36 PM
T-taps maybe.... ? (loose connecter)
Does anyone see what Im gettin at?
Posted By: italnpimp59
Date Posted: February 06, 2005 at 12:46 PM
sounds like you hooked the trunk pop output to the lock wire.
