attler 369D problem explained but...
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=49515
Printed Date: May 01, 2026 at 10:56 PM
Topic: attler 369D problem explained but...
Posted By: devile
Subject: attler 369D problem explained but...
Date Posted: February 06, 2005 at 8:42 PM
Ok, remote start works fine. I diagnosed with voltage tester and found out that yes i had the right wires. HOWEVER, the relay(the once included with 369D system) is clicking, but there is not voltage coming from the relay to the door lock/unlock wires. I hope i didn't leave any details out. THanks in advance for the help
Posted By: auex
Date Posted: February 06, 2005 at 8:46 PM
Are you testing the small gauge blue and green or are you testing the wires coming off of the 451M, at least I think that is what comes with it? If it is the 451M, where is the purple wire hooked up to?
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: devile
Date Posted: February 06, 2005 at 8:52 PM
The purple wire is hooked up to ground. And i'm testing the wires coming off of the 451M.
