Phyton 1500 ESP Remote Start Doesn't Work
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=496
Printed Date: May 11, 2026 at 10:24 AM
Topic: Phyton 1500 ESP Remote Start Doesn't Work
Posted By: sador
Subject: Phyton 1500 ESP Remote Start Doesn't Work
Date Posted: April 27, 2002 at 8:17 PM
Hi, I have a Phyton 1500 ESP and everything was working fine incluiding the remote start also the starter kill relay is hook up.
But one of these day I moved the Alarm brain to another place and then one of the ribbon wire (purple for Stater relay turn-on)It did a contact with the metal frame of the car and the car tried to start the engine and what I did is take the wire off  the metal frame and the starter stop.(The metal frame where this wire did a contact was like a blade so thats why the metal cut the wire and tried to start the car)and after that thing happen the remote start doesn't  work anymore just the alarm.
Does someone know what could be the problem or any idea?or if maybe any relay blow out ....I don't know !!!!!!!!!!!please help meposted_image
Posted By: the12volt
Date Posted: April 27, 2002 at 9:16 PM
Hi sador, check the obvious first...blown fuses for the remote start, the trigger lead to the remote start from the alarm, and if necessary all connections for the remote start.
the12volt
Posted By: Velocity Motors
Date Posted: April 27, 2002 at 11:11 PM
Have you checked the starter relay turn on to see if the relay is still operational ?
Posted By: sador
Date Posted: April 28, 2002 at 8:25 AM
Thank you for you help,first the fuses are ok and then the relay I think is the problem I gonna check that I don't know how but I will.posted_image....hahahahha!
        see youposted_image
Date Posted: April 28, 2002 at 10:40 AM
You can take the relay out by marking the wires in accordance to the pins they are connected to. If you look at the relay with the pins facing you , there are small etched numbers ( 85,86,87,87a & 30 ) make sure that when you cut the wires away from each pin you mark that wire and connect that wire to the new relay in the same pin position. Let us know how you make out.
