MM vs Test Light
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=49667
Printed Date: May 15, 2026 at 11:02 AM
Topic: MM vs Test Light
Posted By: uglyb0b
Subject: MM vs Test Light
Date Posted: February 08, 2005 at 7:29 PM
Hello all. I was wondering if someone could take a few moments and educate me on how (technically) a multi meter is safer than a test light. A long time ago, I installed new stereos in cars. This was way before air bags, computers, etc. I simply used a test light and everything was peachy.
I understand now that using a test light can damage a circuit/blow an airbag/etc, whereas a mutli meter cannot. I am wanting to know why.
I’m not looking for an argument that you need to use a mm over a test light. I get that. I would just like to understand why for me.
For example: is a test light more of an “intrusive” or “active” way of testing, and can complete a circuit (hence blow an airbag)? Whereas a mm is more of a “passive” testing method? In other words, a mm just sits there and tells you whats going on (voltage wise) but doesn’t actually intrude on the circuit like a test light can/will?
Any clarification someone can provide would be appreciated. Thanks.
Posted By: benjammin74
Date Posted: February 08, 2005 at 11:28 PM
you answered your own question. test lights are obsolete. no clarification needed, just be safe and don't use one. its not worth the risk.
car audio pays my bills...
Posted By: kgerry
Date Posted: February 09, 2005 at 9:20 AM
the circuitry of a MM acts as a filter, which prevents blowing things up....
the problem with test lights, even the "computer safe" test lights, is that they illuminate with anywhere from 2 volts to 18 volts..... i've been burned in the past from assuming i had a good connection/circuit because a test light lit up, only to go back to that same circuit after 20 minutes of further troubleshooting and meter it properly with a meter and find out i only have 4 or 6 volts, where i should have had 12 or 14 volts....... this whole industry is about remembering the lessons we learn along the way.... for the past 10-15 years all i use for circuit testing is a good quality digital MM ( analogue when checking for shorted speaker wires )
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: traitorhound
Date Posted: February 09, 2005 at 9:42 AM
kgerry, why analog mm for speaker wires?  just curious
Posted By: riceman
Date Posted: February 09, 2005 at 2:09 PM
Kgerry ,what about the powerlogic II probe, is that a safe probe to use ? I've accidentallly used it when trouble shooting an RS and probe the tach wire by accident and nothing happened. I would never use a powerlogic to find a tach wire. I would use a DMM to find  tach . I've used that snap-on  hummingbird, mac , those all leak ground. I've found the that the powerlogic II probe makes my job alot easier. But I'm still very cautious when using it, when in doubt I still rely on my DMM. I think that with common sense you can use test light & logic probe. But I was wondering what are your opinions on the powerlogic II probe? thanks
Posted By: kgerry
Date Posted: February 09, 2005 at 2:19 PM
no real reason per se, just habit... when you see the needle start to climb you know you have continuity to ground ( where you shouldnt )... i bought a couple of good analogue meters when i opened in the late seventies, early eighties and they still work fine so thats what i use.... it's actually quicker for testing than waiting for a DMM to auto-range....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
Posted By: kgerry
Date Posted: February 09, 2005 at 2:24 PM
i use logic probes for checking data, but never used one to check tach... any DMM with an AC setting will test tach fine....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
