About nissan pathfinder,1999
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=49832
Printed Date: May 13, 2026 at 12:01 AM
Topic: About nissan pathfinder,1999
Posted By: madBedex
Subject: About nissan pathfinder,1999
Date Posted: February 10, 2005 at 5:07 PM
       Hi! Guys.
       Could  anyone please give  me  remote starter wiring info. + tip for nissan
      pathfinder 1999 .
madbedex
Posted By: thepencil
Date Posted: February 10, 2005 at 6:03 PM
1999 Nissan Pathfinder
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|WHITE/ purple        |+ |ignition harness            |
|          STARTER|BLACK / YELLOW        |+ |ignition harness            |
|   SECOND STARTER|RED / blue            |+ |ignition harness            |
|        IGNITION|BLACK/ white        |+ |ignition harness            |
|        ACCESSORY|WHITE/ blue          |+ |ignition harness            |
| SECOND ACCESSORY|RED / yellow          |+ |ignition harness            |
|       POWER LOCK|lt GREEN/ red        |- |keyless entry module *1     |
|     POWER UNLOCK|brown               |- |keyless entry module *1     |
|       LOCK MOTOR|blue               |   |keyless entry module *1     |
|     UNLOCK MOTOR|WHITE/ purple        |   |keyless entry module *1     |
|    DISARM DEFEAT|yellow/black        |   |keyless entry module *1     |
| PARKING LIGHTS +|pink/blue           |   |at steering column          |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|                    |   |                            |
|     DOOR TRIGGER|RED / black           |- |drivers kick panel          |
| TRUNK/HATCH PIN|tied in with doors |   |                            |
|        HOOD PIN|                    |   |                            |
| FCTRY ALARM ARM|yellow              |- |keyless entry module*1      |
|FCTRY ALRM DISARM|light green        |- |keyless entry module*1      |
|       TACHOMETER|blue               |   |at distributor              |
|      SPEED SENSE|WHITE/ yellow        |   |cruise module in DKP        |
|       BRAKE WIRE|GREEN/ YELLOW        |+ |at switch                   |
|     HORN TRIGGER|lt GREEN/ black      |- |steering column             |
|           WIPERS|                    |   |                            |
| LF WINDOW UP/DN|blu/red - blu/blk   |A |drivers door switch        |
| RF WINDOW UP/DN|blu/yel - blu/white |A |drivers kick panel          |
| LR WINDOW UP/DN|RED / blk - grn/wht   |A |drivers kick panel          |
| RR WINDOW UP/DN|wht/blk - blk/wht   |A |drivers kick panel          |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555U. *1 Keyless entry module is located under drivers side of dash.
Be careful whose advice you buy, but be patient with those who supply it.posted_image
