2005 camry remorte start wiring Colors
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=49848
Printed Date: May 12, 2026 at 11:08 PM
Topic: 2005 camry remorte start wiring Colors
Posted By: lookingforvtec
Subject: 2005 camry remorte start wiring Colors
Date Posted: February 10, 2005 at 9:33 PM
I need the wiring color and location for a 2005 camary. I'm installing a remort start alarm. I done an 03 and remember something about having to diode isolating the door pins. Thanks
Dreaming about thing that I want only to away to find things that I can't have... But that's life!! And I deal the best way that I know how..Down shifting and taking it to the red!!!!!
Posted By: thepencil
Date Posted: February 10, 2005 at 10:10 PM
DIRECTWIRE™ WIRING INFORMATION - TOYOTA / CAMRY / 2005 / Remote Start
[PRINT THIS PAGE]
12volts WHITE/ red (30A), white (5A)   +   ignition harness
Starter BLACK/ white   +   ignition harness
Second Starter BLACK / YELLOW   +   ignition harness
Ignition BLACK/ red   +   ignition harness
Second Ignition BLACK / YELLOW   +   ignition harness
Third Ignition N/A
Accessory blue/red   +   ignition harness
Second Accessory N/A
Keysense blue   -   ign harn or BECU, top plug, pin 19
Notes: Using the status output to trigger this wire during remote start will disarm the alarm without unlocking the doors.
The Body ECU is attached to the back of the fuse box under the driver side dash. The plugs for the BECU are on the left side edge.
Power Lock blue / YELLOW   -   DKP or bottom of fusebox, 20 pin plg
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock blue (double pulse)   -   DKP or BECU, top plug, pin 22
Can also use the passenger door key cylinder unlock wire, which only requires a single pulse. It is blue/white (-) in the BECU, top plug, pin 21.
Lock Motor blue/red   5wi DKP or bottom of fusebox, 13 pin plg
Unlock Motor blue/black   5wi DKP or BECU, bottom plug, pin 11
Notes: The Body ECU is attached to the back of the fuse box under the driver side dash. The plugs for the BECU are on the left side edge.
Parking Lights+ green   +   DKP or bottom of fusebox, 20 pin plg
Parking Lights- red   -   switch or BECU, top plug, pin 8
Hazards lt. GREEN/ black   -   switch or BECU, middle plug, pin 10
Turn Signal(L) GREEN / WHITE   +   turn signal flasher relay in DKP
Turn Signal(R) GREEN/ YELLOW   +   turn signal flasher relay in DKP
Reverse Light RED / black   +   DKP or bottom of fusebox, 20 pin plg
Door Trigger see notes   -   see notes
Notes: The LF door is RED / green in the BECU, bottom plug, pin 1. The RF door is RED / green in the BECU, top plug, pin 11. The rear doors are RED / white in the bottom of the fuse box, 20 pin plug, pin 7. Use all three wires and diode isolate each.
Dome Supervision GREEN/ red   -   ignition key cylinder light
Trunk/Hatch Pin green   -   DKP or BECU, bottom plug, pin 6
Hood Pin black   -   theft deterrent ECU behind glovebox
Trunk/Hatch Release WHITE/ blue   5wi DKP or BECU, bottom plug, pin 12
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer BLACK/ orange   ac   ECM behind glovebox
Notes: On the 4 cylinder models, it is in the 2nd plug from the top, pin 1. On the 6 cylinder models, it is in the top plug, pin 5.
Can also go to any ignition coil or fuel injector and use the wire that is NOT BLACK/ red, WHITE/ red, or WHITE/ black.
Wait to start N/A
Brake Wire GREEN / WHITE   +   sw or bottom of fusebox, 20 pin plug
Parking Brake RED / white   -   parking brake switch
Horn Trigger GREEN/ black   -   sw or bottom of fusebox, 24 pin plug
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Immobilizer Bypass Module: Required: Yes Type: Transponder Part #: 556U or 555U
Notes: Standard on the LE V6, SE V6, and XLE models.
Be careful whose advice you buy, but be patient with those who supply it.posted_image
