2004 Ford Explorer
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=50463
Printed Date: April 23, 2026 at 5:18 PM
Topic: 2004 Ford Explorer
Posted By: 02~4.7dak
Subject: 2004 Ford Explorer
Date Posted: February 19, 2005 at 7:39 PM
Im installing a rattler 529D into an 04 ford explorer. I've done tons of remote starters in the past but This Ford is killing me. IT will turn over but never start. I'm using the tach wire on coil pack connected to violet and white. Good ground. two red wires on fords yellow wire. pink to ford RED / lt.green. orange to ford dk. green w/ light green. I only got so far to test unit without bypass transponder. But the key is in the ignition. If the key is in the ON position the vehicle will start. Any help will be great.
Posted By: chris354
Date Posted: February 19, 2005 at 8:13 PM
You need to make sure you have all the ign and acc hooked up. Also on any ford with newer dei system always use uncommon fuel injector wire, if not you will get over rev shutdown. But if the system will not start with the key in ign not turned on then you have not got all wires hooked up. Check to make sure there are no other wires coming off ignition switch that test as acc or ign. I've ran into this where an 02 explorer had another wire that was not listed on tech sheet that needed to be powered.
Date Posted: February 19, 2005 at 8:41 PM
Thanks I'll give a look see and its a 259d not 529d. and do u mean hook the tach wire up to fuel injector wire??? not sure. But thanks and I'll check it out and let everyone know if I ever solve the prob.
Posted By: chris354
Date Posted: February 19, 2005 at 9:04 PM
Yes hook tach up to injector wire.
Date Posted: February 20, 2005 at 1:04 AM
I hooked tach wire to uncommon injector wire and starts fine. and runs for 10 seconds. do i need to teach the tach? any help would be great
Date Posted: February 20, 2005 at 4:24 AM
Now put key in and rs it works fine, I had to teach the tach. try to teach transponder and security light blinks. Now on to the real problem..the 556s transponder. I have the red wire to + 12... black to ground and RED / black to ??? directions say ((-) input) and (connect to active input on rs) how can u connect to inputs together and it do anything and thats exactly what I got...nothing! And I figured since I cant figure out how to wire it up that I will not be able to program it until I do. Please help
Posted By: chris354
Date Posted: February 20, 2005 at 9:01 AM
The RED / black will go to the blue or blue/white status output on the 259d.
