Prostart CT3300 security light prob- GM
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=50658
Printed Date: April 18, 2026 at 11:27 PM
Topic: Prostart CT3300 security light prob- GM
Posted By: lokeefe
Subject: Prostart CT3300 security light prob- GM
Date Posted: February 22, 2005 at 10:57 PM
I installed a prostart CT3300 in my 2000 grand am. Most times it works fine then occasionally it will not start by remote and the security light flashes. I wait for the light to stop flashing (about 10 minutes) and it will start by key. Other times when I start the car by remote the security light will come on (steady, not flashing) later while driving. THis will not happen if I start with the key. I don't understand this because I thought that the starter and bypass modules were no longer being used once you put the key in the ignition and drive the car. ???? I have gone over the connections, they are all soldered. I assume they are all connected to the right wire because it works most times. I have replaced the diode that isolates the bypass module. I have varied the resistance on the bypass module slightly, up and down, same problem. I have tested the ground with a multi meter, there is less than a milli volt between the body and the starter module ground. I would like to rule out all possibilities before I have to buy a new bypass or starter module. Please help!!
Posted By: Montrealler
Date Posted: February 23, 2005 at 1:04 AM
Dont buy a bypass kit for those passloc just use the proper resistor and install between the black and yellow (car side). Passloc is overided 4 ever. Leave the key side of the yellow with no connection isolate with tape.
By The way thieves are not Stupid as soon as they see a car starter antenna they know that it's easy to ground the bypass unit to steal the car.
So try my trick and never be stuck again and as a bonus ask for a refund of the defective bypass unit.
Posted By: gus1
Date Posted: February 23, 2005 at 9:58 AM
Ummm... yeah.... permanent bypass.... seen that done. Not the best idea.
lokeefe> What did you use for a bypass module? A self-learning variety or a dipswitch one?
Gus
------------- Wherever I go, that is where I end up......
Posted By: electra
Date Posted: February 23, 2005 at 10:11 AM
lokeefe - I just started having the exact same issue with mine on my 2000 GMC Sierra. I haven't looked into it yet but I'm guessing a defective bypass module. I been though one already when I installed the unit. I bought mine at Canadian tire and they sold me this crappy dip switched bypass module. This will be my second one replaced but I think this time I will skip this and use the relay and resistor route or does anyone recommend a auto sensing unit I can use? I saw Wal-Mart sells the bull dog auto sensing ones for cheap are they worth it???? sorry if I hijacked the thread
Posted By: Velocity Motors
Date Posted: February 23, 2005 at 10:25 AM
It's the bypass module. Had this happen to a customer's vehicle and replaced the bypass module ( a resistor based one ) with a databus module and ever since then the customer's been happy. Use the GMBP for the Pontiac and it will work fine.
------------- Jeff
Posted By: lokeefe
Date Posted: February 23, 2005 at 11:11 AM
Gus
I used a PATSK-350 for GM passlock I and II and Passkey VATS. Its a dip switch resistor based module. I'd like to try resetting something before I give up on it....I read that you can leave the ignition in the on position for 20 minutes to reset the cars security module. Any idea if that is true?
Posted By: lokeefe
Date Posted: February 23, 2005 at 11:17 AM
OK......I tried a couple of things last night before I posted that message. I disconnected the bypass, checked wiring etc and it worked for me about 7 - 8 times last night. Just tried it this morning and the same problem again, security light is flashing and won't start. I have definetly thought about just going with the resistor. Are there any problems with that besides lack of security? I agree with you about the thieves....the bypass module is accessable anyhow.....I'm sure they could get around it.
Date Posted: February 23, 2005 at 11:18 AM
Yes, that is true. Make sure that all accessories are off when you do this otherwise it will drain your battery. ------------- Jeff
Posted By: lokeefe
Date Posted: February 23, 2005 at 12:25 PM
Have you ever seen this solve a problem? Or should I just replace the bypass?
Date Posted: February 23, 2005 at 1:28 PM
Replacing the module with a databus module will solve the problem. The resistor based modules for certain vehicles just don't work as well. Having the databus modules will comminucate with the Passlock system without cutting Passlock wires and also learns the code without having to worry about climate changes.
------------- Jeff
Posted By: p/t installer
Date Posted: February 23, 2005 at 6:06 PM
replace the bypass unit for a dei unit the 555l is the only one i use for passlock 1 or 2 never ever a problem as long as you are on the correct wires ORANGE / black or black is the ground reference wire and yellow is the resistance wire. connect both the key side and the car side of the resistance wire cause a permanent bypass is the stupidest thing to do, if grounding the ground while running wire is so easy to do when you hide the wires as best you can imagine if you permanently bypass it totally. come on let's face it if a thief wants your car he'll get it regardless of what you do so just keep paying for your insurance because murphy's law always applies and if your car is hot and someone wants it, they'll do thier homework and they'll get it. so dei's 555l is simple to use, just connect the wires start the car with key and let it run for about 5-10 seconds and it's learnt the resistance, stop guessing with dipswitches before you ruin your passlock totally and have to pay a whole lot of money. dei's 555l costs anywhere from 35 - 50 dollars only, so for less headache always go with dei they're the best.
