How do I disable stock alarm 93-4runner ?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=50948
Printed Date: April 18, 2026 at 4:51 PM
Topic: How do I disable stock alarm 93-4runner ?
Posted By: cdempseyca
Subject: How do I disable stock alarm 93-4runner ?
Date Posted: February 27, 2005 at 1:09 AM
I have a 93 4Runner & the alarm automatically sets when you close the door. I want to abandon / disable the alarm completely. It’s very frustrating as you set off the alarm unless you put the keys in the ignition immediately. I’ve read the several other post which talk about getting / programming new remotes Etc. But I don’t need the alarm features anymore. I tried unplugging the control box under the drives seat & then the car won’t start. Any info or references to disable are appreciated. thanks cdempseyca
Thanks.. cdempseyca
Posted By: draasch
Date Posted: February 27, 2005 at 7:50 AM
i dont show a factory system on the yr truck....
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: TJ92Civic
Date Posted: February 27, 2005 at 8:44 AM
I can't find any factory alarm info either.  Are you sure it's not aftermarket?  They probably put a starter kill on it that you can get rid of by reconnecting the starter wires together.
tim
