03 trailblazer remote locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=50962
Printed Date: April 25, 2026 at 10:26 AM
Topic: 03 trailblazer remote locks
Posted By: davi
Subject: 03 trailblazer remote locks
Date Posted: February 27, 2005 at 11:10 AM
i just got a trailblazer with 2 remote locks but neither works so i need to know how to program them im not sure if there original or newer onew but there the same model, they look new but my car was a rental vehicle so i doubt they used it
Posted By: iskidoo
Date Posted: February 27, 2005 at 12:17 PM
Try this:
1 SIT DOWN IN VEHICLE AND CLOSE DOOR
2 HOLD YOUR FINGER DOWN ON THE POWER UNLOCK SWITCH ON THE DRIVERS DOOR.
3 PUT THE KEY IN THE IGNITION, TURN THE IGNITION ON/OFF, ON/OFF. LEAVE THE KEY IN THE IGNITION. (DON'T START THE VEHICLE, THE ON POSITION IS THE RUN POSITION JUST BEFORE START)
4 RELEASE YOUR FINGER FROM THE POWER DOOR LOCK. THE POWER DOOR LOCKS WILL CYCLE.
5 PRESS AND HOLD BOTH THE LOCK AND UNLOCK BUTTONS ON THE NEW REMOTE UNTIL YOU HEAR THE POWER DOOR LOCKS CYCLE. YOU MAY HAVE TO HOLD BOTH BUTTONS DOWN FOR 5-20 SECONDS.
6 TAKE THE SECOND NEW REMOTE AND HOLD BOTH THE UNLOCK AND LOCK BUTTONS DOWN UNTIL THE LOCKS CYCLE.(ANOTHER 5-20 SECONDS)
7 TURN THE KEY ON, THEN BACK OFF.
NOW EXIT THE VEHICLE AND TRY YOUR REMOTES.
Post back your results on the forum.
-Steve
Posted By: davi
Date Posted: February 27, 2005 at 5:29 PM
the locks didnt cycle with either remote but everything did as u said it would, perhaps the bats are dead but there both new so cant see it ill replace em again and try again thanks for the help
Posted By: iskidoo
Date Posted: February 27, 2005 at 6:15 PM
*IF* you have factory installed remote entry, this will work for all years of Trail Blazers. If you do not have the factory installed remote, the locks will cycle again as you are pressing the buttons on the remote, and it will not accept the programming.
The Trail Blazer's are already setup with the components needed for remote entry....it's just a matter of adding the right programming from GM with a Techline terminal. Of course, GM isn't authorizing dealers to do this, so you need to find an accomodating dealer or mechanic with the right tools.
