SmartWindows with matrix 3.5 - 4 Window
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=51005
Printed Date: April 24, 2026 at 4:29 PM
Topic: SmartWindows with matrix 3.5 - 4 Window
Posted By: SpudGunMan
Subject: SmartWindows with matrix 3.5 - 4 Window
Date Posted: February 27, 2005 at 8:48 PM
if using a matrix3.4 and dual Smart Window units. How do you properly hook up 2 smartwindow units to the matrix?
i have the white pages for the single smart window install just wondering the difference to install 2 smartwindow ECU's
Posted By: bretbowman
Date Posted: February 28, 2005 at 1:42 AM
they should daisy chain together through the data port.  I have an Avantguard 5 and it's very similar.  Both of my smart window modules will daisy chain together and I have my cliffnet wizard cable at the end of the chain.  Each smart window module should have the needed cable to allow you to daisy chain them together.
2002 Toyota Sequoia Limited 2WD (Clifford G5 Avantguard 5 w/ 2 SmartWindows modules) - IT Engineer - NRA Life Member - LDS Return Missionary - Married for time AND ETERNITY - Eternally sealed family
Date Posted: February 28, 2005 at 2:44 AM
thank you - looks like i will order two then!
