Alarm Horn
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=51018
Printed Date: April 24, 2026 at 8:48 AM
Topic: Alarm Horn
Posted By: The1Andonly
Subject: Alarm Horn
Date Posted: February 27, 2005 at 11:07 PM
How Do I Make The Cars Horn Go Off WHen The ALarm Does, Instead Of The Regular One THat The Alarm Brings
Posted By: bretbowman
Date Posted: February 28, 2005 at 1:02 AM
You don't want a steady horn sound.  You want a Honk, honk, honk sound (as opposed to a hoooooooooooooooonk sound)    :)
Most alarms have a horn honk output that you can wire into the horn and can also usually program them to honk ONLY when the alarm is triggered.  That way you don't get the horn double honking everything that you lock your doors.  If you're car doesn't have a horn honk output, you could wire a relay off of the parking light flash output, but I'm not sure that's a good idea.  If it was me, I'd probably try it anyway, just for the hell of it.
2002 Toyota Sequoia Limited 2WD (Clifford G5 Avantguard 5 w/ 2 SmartWindows modules) - IT Engineer - NRA Life Member - LDS Return Missionary - Married for time AND ETERNITY - Eternally sealed family
