2003 Jeep Wrangler w/ Audiovox APS25kb
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=51031
Printed Date: April 24, 2026 at 4:02 AM
Topic: 2003 Jeep Wrangler w/ Audiovox APS25kb
Posted By: srees01
Subject: 2003 Jeep Wrangler w/ Audiovox APS25kb
Date Posted: February 28, 2005 at 9:32 AM
I bought a 2003 jeep wrangler with an audiovox aps25kb alarm already installed but completely disconnected. I reconnected all the wires (I think) and put the fuses back in. AS soon as I put the 5A fuse in the alarm goes off and I can't get it off.
I have been trying to get into the programming menu with the remote (I bought a replacement remote online) with no luck. What is the exact way to toggle the valet switch - is it after I turn the key to on or after that?
ANy help or recommendations greatly appreciated.
THanks,
Steve
Posted By: boomer_106
Date Posted: February 28, 2005 at 9:58 AM
Steve try putting your key in the ignition and turning to the run position then install your fuse.
Posted By: srees01
Date Posted: February 28, 2005 at 2:40 PM
boomer_106,
i tried your suggestion, but no luck. I called audiovox and thery said to do the same procedure. I think I must have a bad connection somewhere in the jeep.
Any more suggestions anyone or should i just look to replace at this point?
Thanks for the advice thus far boomer.
Posted By: dare_ds69
Date Posted: February 28, 2005 at 5:50 PM
what wires did you reconect it? ------------- how own your mind, control your life.
MECP certified. always use a DMM
Posted By: srees01
Date Posted: February 28, 2005 at 7:51 PM
Dare,
I reconnected the main collection of wires to the brain module, then a red wire to another red wire in the vicininty of the ignition, then I reconnected a green wire to two wires in the driver's door. Do you think I missed something?
Any help is greatly appreciated.
Steve
