Not sure about Relays ?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=51060
Printed Date: April 23, 2026 at 3:58 PM
Topic: Not sure about Relays ?
Posted By: SouthBound65
Subject: Not sure about Relays ?
Date Posted: February 28, 2005 at 8:19 PM
Hello, New to the 12volt's Electronics Forums. My question is : I have purchased a Galaxy 5000RS Plus
Security System w remote start.  I have installed it but the Instructions are not real clear on whether
I need to Install Relays for my Doom Light,  Parking lights or the Horn. This has been installed in a 2004 Dodge
Ram 1500 Pickup 2 Door. I hope you can Help.
Thank You.
RWB
Posted By: Velocity Motors
Date Posted: February 28, 2005 at 8:47 PM
Most systems require you to add a relay for the dome light , the (+) parking lights for the Dodge are WHITE/ yel (L), WHITE/ gray (R) found at the harness at top of driver fender & the (-) horn trigger is a dk. GREEN/ purple  found at the horn switch. For the horn you can try a direct connection to the horn wire on the alarm system and if it doesn't engage it, then use a relay.
