Make Horn Chirp?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=51121
Printed Date: April 22, 2026 at 4:31 PM
Topic: Make Horn Chirp?
Posted By: bluetruck
Subject: Make Horn Chirp?
Date Posted: March 01, 2005 at 9:37 PM
my Girlfriend drives a 99 pontiac sunfire GT convertable. she has the factory keyless entry but it does not make a sound when she locks it. she wants to make the horn chirp or somethign so she can tell it is locked when she pushes the button. is there a simple way to add a chip (of the horn) to the factory keyless? i was thinking maybe add a relay to the power lock wire? i dont know? any advice would be apreciated. ~Ryan
Posted By: TJ92Civic
Date Posted: March 01, 2005 at 9:48 PM
I dunno, but if you added a relay to the power lock wire to make the horn chirp, it will chirp when you hit the button.
Posted By: Hornshockey
Date Posted: March 01, 2005 at 10:50 PM
Usually on these the horn will sound if you hit the lock button twice
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
Date Posted: March 02, 2005 at 12:35 AM
thats true, is there a better way to do it? (hers never chirps) maybe its broken and supposed to chirp?
Posted By: dare_ds69
Date Posted: March 02, 2005 at 7:03 AM
you can use a relay and a togle switch
86 12v parking lights
85 ground from toggle switch
87 ground
30 goes to horn
you must use the togle switch other ways every time you turn the lights is going to horm
how own your mind, control your life.
MECP certified. always use a DMM
Date Posted: March 02, 2005 at 8:47 PM
why go from the lights? isn't there a small pulse sent for an instant to the door lock accuator? i obviously have no idea what im talkign abotu but arent there other wires  than just the lights to play with? thanks ~Ryan
Date Posted: March 02, 2005 at 10:22 PM
for one, with the lights you'll get a different chirp for lock and unlock, since the lights flash once or twice depending on whether you lock or unlock
