99 Honda Odyssey
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=51132
Printed Date: April 22, 2026 at 7:44 AM
Topic: 99 Honda Odyssey
Posted By: GMC4x4Guy
Subject: 99 Honda Odyssey
Date Posted: March 02, 2005 at 1:18 AM
Is there a way to tell if a 99 Honda Odyssey has an immobilzer? I know with some manufacturers, grey keys have the immobilizer and the black ones don't. Is this the case?
"Drive it like you stole it"
Posted By: Velocity Motors
Date Posted: March 02, 2005 at 1:35 AM
All Odyssey's from 1998 + have the immobilizer system in them. A cheap way to find out is to get a plain key cut and try to start the van. If it does then someone bypassed the system already, if it doesn't start, then the Immobilizer system is intact.
Date Posted: March 02, 2005 at 2:36 AM
I will try that. Thanks
Posted By: dare_ds69
Date Posted: March 02, 2005 at 6:44 AM
you can see in the cluster if a key blinks when you take the key from the ignition
how own your mind, control your life.
MECP certified. always use a DMM
