1997 Camry Tach Wire?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=51318
Printed Date: April 19, 2026 at 3:42 PM
Topic: 1997 Camry Tach Wire?
Posted By: Hornshockey
Subject: 1997 Camry Tach Wire?
Date Posted: March 04, 2005 at 11:34 PM
I'm installing a remote start on a 97 Camry 4cyl. The wiring info I've got lists the tach as blk/orange at the ECM behind the glove box.  There are three black and orange wires in this bundle, but none of them test corretly as the tach wire.  Anybody done one of these know exactly which wire it is, or perhaps another place I can grab the tach?  Have it running tachless off crank time right now, but I would much rather hook up the tach.
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
Posted By: gcorrea
Date Posted: March 05, 2005 at 12:00 AM
4 cylinder engine is black wire in the gray plug at the coil on drivers side of motor.
6 cylinder engine is gray wire at ignitor on a braket in front of the strut tower. module is labeled DENSO.
double check your wires with you dmm.
gcorrea
