Ground when armed output
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=5140
Printed Date: May 04, 2026 at 1:06 PM
Topic: Ground when armed output
Posted By: hiluxrunner
Subject: Ground when armed output
Date Posted: November 04, 2002 at 11:52 PM
I have an ungo MS2005 alarm. On the ground when armed output im currently sending a ground signal to 3 window modules and a starter kill relay. The (-) output is rated at 500mA. Do i need to install a relay to supply better ground for all of my modules? If so what wires should go on each post to do so? Thanks!!
Chris
Posted By: securinu
Date Posted: November 05, 2002 at 12:59 PM
No you dont want to do that , because your relay will be open all the time drawing current. it would run your battery down much quicker.
