04 f250 remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=51471
Printed Date: May 16, 2026 at 4:43 PM
Topic: 04 f250 remote start
Posted By: johnny567
Subject: 04 f250 remote start
Date Posted: March 07, 2005 at 6:14 PM
Ijust installed A code alarm ca-640 remote starter in my 04 f-250 6.0 diesel when i use tach mode it will shutdown at varying times (30sec to 2.0min) i know the tach wire is working because when i rev the motor it will quit like it is supposed to. If i put on blind crank it works just fine. anyone had this problem? any suggestions? thanks.
Posted By: circus boy
Date Posted: March 07, 2005 at 7:13 PM
code remote starts are funny like that some times i have done two or 3 f250 1 gas 2 diesel.one diesel i ran it tach and itworked fine, the other i had to run tachless both worked fine. so i wouldn't worry about it unless it gives you problems when it is verry cold and it sits over night
Posted By: NowYaKnow
Date Posted: March 07, 2005 at 8:59 PM
You either need to try learning the tach at a different RPM, or get their CTO (clean tach output) tach booster module and add that.
Mike
Posted By: auex
Date Posted: March 07, 2005 at 9:34 PM
I also have had wierd problems like that with the ford diesels. Never did find out what the problem was, but switched it over to voltage sensing and it worked fine.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: March 12, 2005 at 12:02 PM
i contacted code tech support and they said to grab the tach at the computer for a stroger signal i havent tried yet will let you know if it works.
