Ford Explorer factory alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=51480
Printed Date: May 01, 2026 at 12:48 PM
Topic: Ford Explorer factory alarm
Posted By: DukeDuke
Subject: Ford Explorer factory alarm
Date Posted: March 07, 2005 at 7:42 PM
Well, I posted a while back about adding another remote to a ford explorer. However, my dads heater hasn't been working, so he thought it was a fuse, so he went though and pulled every fuse in the explorer. So, he pulled the fuse for the alarm I guess... So, the problem that I am dealing with is, his pad on the outside of his car no longer works nor does his remotes, does anyone have any idea how to fix this and make everything work again! Thanks for the help!
------------- Duke Duke
Posted By: DukeDuke
Date Posted: March 08, 2005 at 9:52 PM
Does anyone know how to reset this? I know with adding a new remote you turn it off and on, however that doesn't seem to work in this case, please help!
Posted By: ponchsmart
Date Posted: March 08, 2005 at 11:25 PM
Are you talking about the original remotes or after market. And regardles of the key pad, are you using a personal code or the factory number, the factory number by the way can be found some times on a little sticker inside the glove box or the back door some where around the edge, (same option, on a white little sticker).
