03 toyota spyder, remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=51502
Printed Date: May 01, 2026 at 6:57 PM
Topic: 03 toyota spyder, remote start
Posted By: INSTALLTECH323
Subject: 03 toyota spyder, remote start
Date Posted: March 07, 2005 at 11:54 PM
has anyone installed a remote start on this vehicle? how did you get around the bypass switch on the brake switch??
MECP CERTIFIED TECH
Posted By: profuse007
Date Posted: March 08, 2005 at 4:27 AM
specifically what are you trying to do w/ the brake switch?
are you trying to find the e-brake for MT compatible RS units?
Houston,TX
Date Posted: March 08, 2005 at 10:23 PM
no im trying to install a remote start unit to this vehicle, but in order for this vehicle to crank over you have to press on the brake pedal to start it
MECP CERTIFIED TECH
Date Posted: March 09, 2005 at 2:22 AM
very not familiar w/ these types of starter bypass. first time hearin that a car has to press on the brake to start, i assume this is a automatic tranny.
the brake wire is GREEN / WHITE, 12v+ when applied.
Houston,TX
Posted By: Velocity Motors
Date Posted: March 09, 2005 at 7:58 AM
Set up a relay that will engage the brake wire like it would a clutch. Use the status output wire from the unit.
