CT3300
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=51554
Printed Date: May 02, 2026 at 7:20 AM
Topic: CT3300
Posted By: denis mcginn
Subject: CT3300
Date Posted: March 08, 2005 at 4:09 PM
I'm trying to install ct3300 on 2000 venture van, I had every thing working fine. Then I decided to change some programming functions. Now van will not start, flashes lights 3 times(hardware reset????) is what manual says, locks work fine and no security on van.
Any help would be great!!! Thanks, denis
Date Posted: March 09, 2005 at 8:01 AM
To add the above thread, the parking lights flash 3 times and then the module shuts down, and vehicle does not start.
Posted By: profuse007
Date Posted: March 09, 2005 at 12:20 PM
whats does the 3flashes mean?
pull up the shutdown history, look in install manual.
what was teh programming you changed?
Houston,TX
Date Posted: March 09, 2005 at 1:53 PM
Thanks for the reply, three flashes means "remote start attempt cancelled by remote". I changed the "ignition controlled door locks" and starter kill to "active", no starter kill installed
Date Posted: March 09, 2005 at 1:57 PM
Three flashes means "remote start attempt cancelled by remote" or it also says "entering cold start mode" all I changed was "ignition controlled door locks and starter kill to "active" because I did not install starter kill option.
Posted By: thepencil
Date Posted: March 10, 2005 at 11:05 AM
Get yourself out of valet mode. You are probably in valet mode right now.
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Date Posted: March 14, 2005 at 1:57 PM
Thank you for the advice, everything is okay now!!!
