1998 jeep cherokee, keyless entry
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=52010
Printed Date: May 13, 2026 at 6:24 AM
Topic: 1998 jeep cherokee, keyless entry
Posted By: maroda
Subject: 1998 jeep cherokee, keyless entry
Date Posted: March 16, 2005 at 3:44 PM
hello everyone i need to know the correct way to install keyless intry what color wires and is it reverse polarity and also tach wire.  please help
maroda
Posted By: dare_ds69
Date Posted: March 16, 2005 at 6:34 PM
12volts red & pink/black   +  ignition harness
Starter yellow   +  ignition harness
Second Starter
Ignition dark blue   +  ignition harness
Second Ignition BLACK/ orange   +  ignition harness
Third Ignition
Accessory BLACK/ white   +  ignition harness
Second Accessory
Keysense
Power Lock ORANGE / purple   -  drivers kick panel
Notes: Must use relays to trigger the lock and unlock wires. Close all doors when testing.
Power Unlock pink/purple   -  drivers kick panel
Lock Motor see direct fax
Unlock Motor document #1074
Parking Lights+ BLACK / YELLOW    headlight switch
Notes: Also found in a large connector at the junction block in the passenger kick panel.
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger yellow   -  drivers kick
Notes: In a gray 2 pin connector.
Dome Supervision
Trunk/Hatch Pin tied in with door
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer gray   AC black plug at PCM
Notes: The PCM (powertrain control module) is located on the drivers side inner fender well near the radiator support.
Wait to start
Brake Wire WHITE/ tan   +  brake switch
Parking Brake
Horn Trigger BLACK/ red   -  steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
posted_image
Immobilizer Bypass Module:Required: NoType: N/APart #: N/A
https://www.directechs.com/techtips/pdfs/resources/security/directed_techtips/1074.pdf
how own your mind, control your life.
MECP certified. always use a DMM
