| Print Page | Close Window |
Door switch wiring 2005 camryPrinted From: the12volt.comForum Name: Car Security and Convenience Forum Discription: Car Alarms, Keyless Entries, Remote Starters, Immobilizer Bypasses, Sensors, Door Locks, Window Modules, Heated Mirrors, Heated Seats, etc. URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=52070 Printed Date: May 14, 2026 at 2:10 AM Topic: Door switch wiring 2005 camry Posted By: Seamus1967 Subject: Door switch wiring 2005 camry Date Posted: March 17, 2005 at 6:43 PM Ok i found the wires for the passenger and driver doors here is the question I have one postive and negative wire from the alarm module . Would I be able to use a chassis ground for the negative and the two single wires on the door switchs which I believe are positive and splice them together with the one positive wire from the mudule. Seeing how both are switchs and there grounded to the chassis .. I dont know you tell me am I wrong ...
Replies: Posted By: thepencil Date Posted: March 17, 2005 at 7:23 PM You will only need to use either postive or the negative wire from the alarm module, but don't use both. Below is the wiring diagram for your car.
You can get the trigger here: Dome Supervision, GREEN/ red - negative polarity at the ignition key cylinder light DIRECTWIRE™ WIRING INFORMATION - TOYOTA / CAMRY / 2005 / Remote Start 12volts WHITE/ red (30A), white (5A) + ignition harness Starter BLACK/ white + ignition harness Second Starter BLACK / YELLOW + ignition harness Ignition BLACK/ red + ignition harness Second Ignition BLACK / YELLOW + ignition harness Third Ignition N/A Accessory blue/red + ignition harness Second Accessory N/A Keysense blue - ign harn or BECU, top plug, pin 19 Notes: Using the status output to trigger this wire during remote start will disarm the alarm without unlocking the doors. The Body ECU is attached to the back of the fuse box under the driver side dash. The plugs for the BECU are on the left side edge. Power Lock blue / YELLOW - DKP or bottom of fusebox, 20 pin plg Notes: Meter this wire while turning the key in the driver door key cylinder. Power Unlock blue (double pulse) - DKP or BECU, top plug, pin 22 Notes: Meter this wire while turning the key in the driver door key cylinder. The Body ECU is attached to the back of the fuse box under the driver side dash. The plugs for the BECU are on the left side edge. Can also use the passenger door key cylinder unlock wire, which only requires a single pulse. It is blue/white (-) in the BECU, top plug, pin 21. Lock Motor blue/red 5wi DKP or bottom of fusebox, 13 pin plg Unlock Motor blue/black 5wi DKP or BECU, bottom plug, pin 11 Notes: The Body ECU is attached to the back of the fuse box under the driver side dash. The plugs for the BECU are on the left side edge. Parking Lights+ green + DKP or bottom of fusebox, 20 pin plg Parking Lights- red - switch or BECU, top plug, pin 8 Notes: The Body ECU is attached to the back of the fuse box under the driver side dash. The plugs for the BECU are on the left side edge. Hazards lt. GREEN/ black - switch or BECU, middle plug, pin 10 Notes: The Body ECU is attached to the back of the fuse box under the driver side dash. The plugs for the BECU are on the left side edge. Turn Signal(L) GREEN / WHITE + turn signal flasher relay in DKP Turn Signal(R) GREEN/ YELLOW + turn signal flasher relay in DKP Reverse Light RED / black + DKP or bottom of fusebox, 20 pin plg Door Trigger see notes - see notes Notes: The LF door is RED / green in the BECU, bottom plug, pin 1. The RF door is RED / green in the BECU, top plug, pin 11. The rear doors are RED / white in the bottom of the fuse box, 20 pin plug, pin 7. Use all three wires and diode isolate each. The Body ECU is attached to the back of the fuse box under the driver side dash. The plugs for the BECU are on the left side edge. Dome Supervision GREEN/ red - ignition key cylinder light Trunk/Hatch Pin green - DKP or BECU, bottom plug, pin 6 Notes: The Body ECU is attached to the back of the fuse box under the driver side dash. The plugs for the BECU are on the left side edge. Hood Pin black - theft deterrent ECU behind glovebox Trunk/Hatch Release WHITE/ blue 5wi DKP or BECU, bottom plug, pin 12 Notes: The Body ECU is attached to the back of the fuse box under the driver side dash. The plugs for the BECU are on the left side edge. Power Sliding Door N/A Factory Alarm Arm arms with lock Factory Alarm Disarm disarms with unlock Disarm No Unlock use key sense wire Tachometer BLACK/ orange ac ECM behind glovebox Notes: On the 4 cylinder models, it is in the 2nd plug from the top, pin 1. On the 6 cylinder models, it is in the top plug, pin 5. Can also go to any ignition coil or fuel injector and use the wire that is NOT BLACK/ red, WHITE/ red, or WHITE/ black. Wait to start N/A Brake Wire GREEN / WHITE + sw or bottom of fusebox, 20 pin plug Parking Brake RED / white - parking brake switch Horn Trigger GREEN/ black - sw or bottom of fusebox, 24 pin plug Memory Seat 1 N/A Memory Seat 2 N/A Memory Seat 3 N/A Immobilizer Bypass Module: Required: Yes Type: Transponder Part #: 556U or 555U Notes: Standard on the LE V6, SE V6, and XLE models. This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter. Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information. ------------- Be careful whose advice you buy, but be patient with those who supply it. ![]() |
